The Statistics view provides detailed statistic information on the assets using the selected application in the specified time span.
This view has the following information:
Specifies the maximum, minimum, and average number of concurrent uses of the selected application.
Shows the average number of times the selected application has been in use in the specified time span. For example, if the Average value is 2.5, the application has been used two to three times in the specified time span.
Note: The Average value can serve as an indicator for the numbers of licenses needed in your company.
Counts the number of occurrences of the following events for the selected application:
Counts the number of times the application was started and the total number of different users running the application.
