Previous Topic: Import to DBNext Topic: Mark Time Interval in the Graph
Graph View
The graph area provides a report on the selected application for a defined period.
In the Graph the dotted horizontal line indicates when the permissible number of licenses was exceeded. This number is configurable in the Add Application for Monitoring tab of the Properties for software usage collect task dialog.
Time
Shows the time (x-axis) of the concurrent use of the selected application. The content of the field will be the time corresponding to the position of the cursor. It will vary as the cursor is moved over the screen.
Used
Shows the number of the concurrent users of the selected application.
More information:
Configure Parameters for Monitored Application
