Previous Topic: Reschedule JobNext Topic: Software Delivery Halted
Reschedule Target Job
You can reschedule a target job, if the job activation time set up is still at a future moment of time, that is the job is still in Waiting state (it has not gone to Active state).
Note: Possible only, if the job has been set up with the No Linkage option)
You can proceed along two different lines when rescheduling a job.
Expand jobs and select the job of interest in the left tree. The job targets will be listed in the right pane. Select the computer of interest, right-click and select Reschedule in the context menu.
The Reschedule Job dialog opens, where you can set up date and time for the job, using the same calendar as in setup date and time.
You can also expand the jobs folder for a specific computer and select the job of interest in the right pane. Right-click and select Reschedule in the context menu to open and complete the Reschedule computer job dialog in the same way as above.
