The Offline Utilization window lets you view usage information in different ways.
The Data menu in this window contains the following options:
Opens the Offline Utilization window that displays the offline utilization information of the selected software.
Opens the Online Utilization window that displays the online utilization information of the selected software.
Opens the Queue application name window that displays the currently queued assets that have been prevented from launching the application.
Opens the Release of Application dialog that displays the assets in queue.
Displays all activities concerning the .dll and/or .exe files to be monitored are displayed.
Imports the current utilization data into the domain database.
The View menu contains the following menu options:
Plots the usage information (for a defined period) on a graph.
Provides detailed statistic information on the assets using the selected application in the specified time span.
Provides time-related information about the selected asset in list form.
The Filter menu contains the following menu options:
Activates the actions that appear in the list that follows.
Shows those applications that have been prevented from execution.
Shows those applications that have been started and stopped normally.
Shows those applications that have been started with a warning and stopped normally.
Shows those applications that have been started normally and stopped by the Software Usage agent.
Shows those applications that have been started with a warning and stopped by the Software Usage agent.
Specifies the start time for view in the Start Time field and stop time for view in the Stop Time field.
Defaults: Start Time = today minus two whole days; Stop Time =today
