If you select more than one software name in the Name field, then the changes made in the Deliver at and Activate at fields apply to the selected software items.
For Deliver at, the date/time setting does not apply for any other item(s) listed in the Name field.
For the Activate at field, any change for any item will make this setting common for all items (just as the default setting, when you enter this dialog).
You cannot set any activation time to be earlier than the corresponding delivery time. This is blocked by Software Delivery.
The General tab for Jobs displays the individual Deliver at dates and times and the common Activate at dates and times.
If you select the job container, the right pane displays the date/time settings for the individual jobs in the Deliver time and the Activation time columns.
