The DSM Explorer › Control Panel › Domains › Add a New Domain
Add a New Domain
You can add a new domain to the scope of an enterprise manager.
The following considerations apply when you are linking a domain manager to an enterprise manager:
- You can link only FIPS-only domain managers to a FIPS-only enterprise manager.
- When the FIPS mode of the domain manager or the enterprise manager is FIPS-Preferred (Ready for FIPS-Only) or FIPS-Preferred (Re‑run conversion for FIPS-Only), you cannot perform a link operation.
- If the enterprise manager is in FIPS-preferred mode, you can link FIPS-preferred or legacy domain managers to it.
To add a new domain to an enterprise
- Right-click the Control Panel, Domains, All Domains in the Enterprise Manager node.
- Select New Domain from the context menu that is displayed.
The New Domain Wizard appears. It is a task-oriented wizard that guides you through the process of adding, or joining, an existing domain to the enterprise.
