Previous Topic: External Asset Properties: External Asset TabNext Topic: History - External Asset Folder
External Asset Properties: User-Defined Tab
The User Defined tab lets you specify additional information about user-defined properties.
Use the User data fields to associate any kind of information with the current asset. These fields can be referred to in queries and reports.
Note: In the software delivery agent, a user profile is a manageable unit that can run jobs in the security context of the user. When the user profile is enabled, the data you enter using the System Tray applies to the currently logged-on user profile, not the computer. You can add data for the computer, however, from the command line window using the following command:
sd_acmd userinfo user=username location=location phone=phone comment=comment target=
For more information on sd_acmd, see the Software Delivery CLI Reference Guide.
To send the data to the server, use the command:
caf register
For more information about the caf command, type <command> /? at the command prompt.
