You can customize the font face, size, style, and color of the custom administrator messages based on your requirements. To do the customization, open the agent.txt file and make necessary updates in the [USER_MESSAGE] section of the file. The agent.txt file is available under the location ..\Program Files\CA\DSM\SD\NLS.
A sample [USER_MESSAGE] section is given below:
[USER_MESSAGE]
; Font face to be used, default is Tahoma
1 = Tahoma
; Font Size. Specifies the character height. The dialog is not resized due to this setting
2 = 10
; Font Style. We have to set B for Bold, I for Italics, U for Underline. The dialog is not resized due to this setting
3 = B
; Following 3 values are for RGB, these values can be used to set the color of the user message
; Value for R
4 = 0
; Value for G
5 = 50
; Value for B
6 = 175
