Previous Topic: Database Table: Policy StatusNext Topic: Select Field Dialog
Database Table: Software Usage
Note: Available categories and options may vary depending on the products and components installed.
The Software Usage table, INFOHIS, stores information about the offline software usage.
This table contains the following columns:
ACID
Includes the Action ID.
Example:
MHISAC_PREVENTED = 0
MHISAC_NORMAL_NORMAL = 1
MHISAC_WARNING_NORMAL = 2
MHISAC_NORMAL_ABNORMAL = 3
MHISAC_WARNING_ABNORMAL = 4
MHISAC_QUEUED_GRANTED = 5 (The number of minutes the user was in queue for this application.)
MHISAC_NORMAL_INACTIVITY = 6, (Started normal, Inactivity stop.)
MHISAC_WARNING_INACTIVITY = 7 (Started with warning, Inactivity stop.)
APFLAG
Indicates whether the software usage entry was collected by the engine or by importing online data.
DOMAIN_UUID
Includes the UUID of the domain instance.
ENDDATE
Includes the date when the application was last stopped
ENDTIME
Includes the time when application was last stopped
ENDTOTAL
Includes the total of ENDTIME, seconds since 1970.1.1.
OBJECT_TYPE
Includes the type of object.
Example: ca_discovered_hardware=1, ca_discovered_user=2.
OBJECT_UUID
Object UUID. Foreign key to either ca_discovered_hardware or ca_discovered_user depending on object_type.
STDATE
Includes the start date when application was launched
STTIME
Includes the start time when application was launched
STTOAL
Includes the start date and time
SW_DEF_UUID
Includes the software definition UUID of the monitored application.
SW_DOMAIN_UUID
Includes the software domain UUID of the monitored application.
More information:
Add Advanced Argument Dialog
