Previous Topic: Database Table: Job StatusNext Topic: Database Table: Policy Status
Database Table: Module Status
The Module Status table, STATMOD, stores the collect task status information.
This table contains the following columns:
AUTO_REP_VERSION
Includes the automatic increment counter used by the replication engine for comparing the values before and after the update.
MDOMID
Includes the module domain ID.
MOID
Includes the module ID.
OBJECT_DOMAIN_UUID
Includes the object domain UUID used for replication.
OBJECT_TYPE
Includes the type of object.
Example: ca_discovered_hardware=1, ca_discovered_user=2.
OBJECT_UUID
Object UUID. Foreign key to either ca_discovered_hardware or ca_discovered_user depending on object_type.
STATUS
Includes the collect task status.
STCOUNT
Includes the number of times the collect task has been executed.
STDATE
Includes the date of last status update.
STELAPSE
Includes the elapsed time for the last execution of the collect task (in seconds).
STFLAG
Indicates whether status text is required.
Example: 0=None, 1=More
STQCOUNT
Includes the number of times the collect task has been cancelled.
STREV
Includes the revisions number
STTEXT
Includes the status text. This column can contain up to 127 characters.
More information:
Add Advanced Argument Dialog
