You can use the DSM Explorer search functionality to search for computers, user accounts, and so on. The search is performed based on the search criteria you enter in the search field of the Search for category name portlet. If you do not provide any search criteria in the search field (that is, leave the field blank), the DSM Explorer search functionality considers the blank field as a wildcard (*) expression and displays all the items belonging to the searched category. For example, while searching for the computers, if you do not specify any search criteria in the Computer Name field on the Search for computers portlet (select Search Computers from the context menu of the Computers and Users node), the DSM Explorer search displays all the computers.
