Previous Topic: Enterprise Properties Dialog - Root NodeNext Topic: Properties Dialog - Database Tab
Properties Dialog - Enterprise Tab
The Enterprise tab contains information about the DSM enterprise you have selected to browse.
Note: This tab is only available when connected to an enterprise manager.
This tab has the following fields:
Name
Specifies the name of the enterprise.
Created
Displays the date when the enterprise was created.
Changed
Displays the date when the enterprise was last modified.
Contact information
Specifies ownership information about the enterprise.
Description
Describes the enterprise.
Note: The Name, Contact information, and Description fields can be modified at the root level, and this information is replicated between enterprise and domain managers.
