Previous Topic: Security Profile Linkages DialogNext Topic: Security Area Linkages Dialog (Secured Objects)
Security Area Linkages Dialog (Security Profiles)
The Security Area Linkages dialog lets you enable the security area support for one or more profiles, and link or unlink the security profiles with the security areas.
This dialog contains the following fields:
Security Profile
Displays the name of the selected security profile. If you have selected multiple profiles, this field displays the number of profiles selected, for example, Multiple Profiles (4).
Enable Security Area support for this profile
Enables or disables the security area support for the selected security profiles. This check box is grayed if the different profiles have different Enable state. You can select or clear the grayed check box to enable or disable the security support for all the selected security profiles or you can leave it unchanged.
Note: When you add a profile, this option is enabled or disabled based on whether the security area support on domain manager (Global Setting) is turned on or off.
List of Security Areas
Lists all the security areas and their linkage status in relation to the selected security profiles. The Linkages column can have the following values based on the linkage status of the selected profiles in relation to each security area:
Linked
Indicates that the security area is linked to all the selected security profiles.
Unlinked
Indicates that the security area is not linked to any of the selected security profiles.
Different
Indicates that the area has a mixed linkage status that is, linked to at least one and unlinked from at least one security profile. This status is possible only when you select multiple profiles.
Note: An asterisk (*) before the linkage status indicates the status change after the dialog is displayed.
Link
Links the selected security areas to the selected security profiles. This button is enabled if the linkage status of at least one of the selected security areas is Unlinked or Different.
Unlink
Unlinks the selected security areas from the selected security profiles. This button is enabled if the linkage status of at least one of the selected security areas is Linked or Different.
Reset
Resets the linkage status to the previously saved value. This button is enabled if the linkage status of at least one of the selected security areas is changed after the dialog is displayed. A changed linkage status has a leading asterisk (*).
