The DSM Explorer user interface does not display information about the concurrency status of the Installation Manager. To confirm whether the Installation Manager is running in concurrent mode or non-concurrent mode, you need to run the caf status command on the domain manager to check the status.
If the caf status command displays the Installation Manager (sdmgr_im) and Notification Manager (sdmgr_nm) plug-ins in the running state, it implies that the Installation Manager is running in concurrent mode.
