Previous Topic: Edit OS Installation Parameter BootNormalNext Topic: Edit OS Installation Parameter Domain
Edit OS Installation Parameter BootSpecial
Parameter Name:
BootSpecial
Specifies the boot image used to install this operating system image.
Note: If this parameter has the BDSM--FIPS-unqualified--ICOicon, it means that at least one of the boot images assigned to the different OS installations is not FIPS-compliant. You can view the See Also portlet to view all the OS images associated with the selected image.
Parameter Type:
Text (BootImage)
Maximum length:
12
Default value:
osinstal.2
Comment:
'boothd' of first boot image for operating system installation ('osinstal.2')
