You can delete heuristic software definitions and their corresponding discovered inventory.
To delete heuristic software definitions and discovered inventory
The right pane displays all software definitions.
A context menu appears.
CA ITCM deletes the definitions and corresponding inventory items.
Note: You can also disable all heuristic scanning if you no longer want to collect heuristic software data. To do so, disable the heuristic scan collect tasks on the enterprise and domain managers. For more information on how to disable heuristic scan collect tasks, see the Disable a Collect Task, Unlink a Collect Task from an Asset, and Delete a Collect Task procedures.
