Previous Topic: How Deployment WorksNext Topic: Running Deployment on Different Platforms
Prerequisites
Before you start deploying the agents, you must have the CA ITCM manager installed. The target computer must be able to communicate with a manager.
The agent package that you are deploying must be available on the deployment manager or a scalability server. The installation process determines which agent packages are available. Extra packages may be added to the deployment library after installation using the dsmPush utility.
Note: For more information about the installation process and the dsmPush utility, see the Implementation Guide. For details about system requirements for the CA ITCM agent plug-ins, see the CA IT Client Manager Readme file.
