Previous Topic: Add Security Profiles DialogNext Topic: Re-map Security Profile Dialog
Modify Security Profiles
You can modify an existing security profile to remap it to another security principal. In this case, the existing permissions at the class, object and group level remain the same. Remapping a profile is helpful when you want a user to take over the permissions of another user.
To modify a security profile
  1. Select the profile to be modified in the Security Profiles dialog and click Re-map.
    The Re-map Security Profile dialog appears.
    Note: You must have the access rights to open this dialog; otherwise, a security error message is displayed. Administrators (on Windows) and root (on UNIX) have these access rights by default.
  2. Make the necessary changes, and click OK.
    The modified profiles are saved to the database.
More information:
