Previous Topic: Deployment Job Status PaneNext Topic: Delete a Job
Change the Status of a Deployment Job
A deployment job can have one of the following statuses:
To change the status of a deployment job
  1. Right-click the job in the Deployment Job Status pane.
    A context menu appears, displaying the following options:
  2. Click the appropriate option to change the status of the job.
Note: If you suspend a deployment job, and target computers within the job are currently actively deploying, these deployments will continue. However, no new deployments occur within this job until you click Resume.
