The lower part of the Edit OS Installation Parameter window contains a short parameter description as it was specified during the associated operating system images build. Depending on the type of parameter, the description contains the following information:
Specifies the parameter type
Specifies the maximum character length of the parameter value
Specifies the minimum character length of the parameter value
Specifies the upper limit for a feasible parameter value
Specifies the lower limit for a feasible parameter value
Specifies the default value assigned for the selected parameter
Specifies a comment on the parameter specified during the build of the associated operating system image
Provides any simple text string. The length of the string can be limited by the MaxLength attribute. The following parameter attributes are valid for this parameter type:
Attribute |
Meaning |
Range |
MaxLength |
Maximum length of the strings to be assigned |
1 to 255 characters |
Comment |
Comment on the parameter |
any string |
Trans |
Drives the inheritance of parameter settings |
{yes|no} |
UpdateDefault |
Overwrites the default value when updating the image |
{yes|no} |
Specifies a numeric value. The range of the value is given by the attributes MaxValue, which specifies the maximum, and MinValue, which specifies the minimum. The value of MinValue must be less than or equal to the value of MaxValue. The following parameter attributes are valid for this parameter type:
Attribute |
Meaning |
Range |
MaxValue |
Maximum of the value assigned |
-2147483648 to 2147483647 |
MinValue |
Minimum of the value assigned |
-2147483648 to 2147483647 and MinValue <= MaxValue |
Comment |
any string |
Trans |
{yes|no} |
UpdateDefault |
{yes|no} |
Provides an encoded password. The password can be limited to MaxLength characters. A password is always related to a user ID. The following parameter attributes are valid for this parameter type:
Attribute |
Meaning |
Range |
MaxLength |
Maximum length of the password to be assigned |
Comment |
any string |
Trans |
{yes|no} |
UpdateDefault |
{yes|no} |
TextListExt specifies a list of item=<string>; that is, it is the same as a TextList parameter, but the list can be extended with the parameter editor later on.
Attribute |
Meaning |
Range |
MaxLength |
Maximum length of a list entry |
Comment |
any string |
Trans |
{yes|no} |
UpdateDefault |
{yes|no} |
Item |
Specifies a list item. This attribute can occur more than once. |
any string |
Specifies a list of item=<string1> <string2>. String2 is shown in the editor only, when string1 has been assigned a value.
The parameter editor can extend parameters of type MapListExt, but not of type MapList.
When assigning a value to a parameter, it can only be a string that is appearing in the list.
The following parameter attributes are valid for these parameter types:
Attribute |
Meaning |
Range |
MaxLength |
Comment |
any string |
Trans |
{yes|no} |
UpdateDefault |
{yes|no} |
Item |
"string1" "string2" |
Specifies the name of a boot image. The following parameter attributes are valid for this parameter type:
Attribute |
Meaning |
Range |
MaxLength |
Maximum length of the boot image name |
1 to 8 characters |
Comment |
any string |
Trans |
{yes|no} |
UpdateDefault |
{yes|no} |
Specifies the name of an operating system image. The following parameter attributes are valid for this parameter type:
Attribute |
Meaning |
Range |
MaxLength |
Maximum length of the operating system image name |
1 to 10 characters |
Comment |
any string |
Trans |
{yes|no} |
UpdateDefault |
{yes|no} |
