Previous Topic: Submit Query: Select EngineNext Topic: View Saved Query Result
Run a Query
After a query is designed, you can run the query to view the results.
To run a query
  1. Select the query you want to execute.
  2. Click Run Query in the Tasks section.
    The query is executed and the results are displayed in the Query Preview dialog.
Note: The query execution times out after every 5 minutes with a message that allows you to either continue or cancel the query execution. At any time during the execution, you can press the Esc key to cancel the execution.
Note: Queries submitted to the engine run automatically.
