You can specify object permissions for each object, such as a computer, a user, a job, and so on. By default, an object inherits the class permissions from its object class.
Note: Object permissions takes precedence over class and group permissions.
To specify object permissions
The Object Permissions dialog appears.
Note: You can select multiple object classes and specify the class permissions for all of them. For continuous selection, press the Shift key and then click the objects; for random selection, press the Ctrl key and then click the objects.
The members of the profile can access with the rights granted to them.
To specify different combinations of rights, select Special access in the object access drop-down list.
