Previous Topic: How SS Handles Messages—Bulk Update Disabled, Stage Check EnabledNext Topic: How SS Handles Messages—Bulk Update Disabled, Stage Check Disabled
How SS Handles Messages—Bulk Update Enabled, Stage Check Enabled
When you configure the scalability server to run in both the modes, the stage check interval takes precedence over the bulk update interval, but the messages are sent in bulk. For example, if you configure the scalability server to perform stage check after every 60 minutes and bulk update after every 10 minutes, the scalability server sends the messages to the Installation Manager in bulk after every 60 minutes. The scalability server ignores the bulk update interval.
In this scenario, the scalability server handles the messages in the following manner:
  1. Scalability server caches the messages that it receives from the agents for a specified period (stage check interval). The scalability server ignores the bulk update interval.
  2. Scalability server sends the messages to the Installation Manager when one of the following conditions is met:
  3. Scalability server sends the messages in bulk in the form of a single message, containing various submessages, to the Installation Manager.
As the scalability server sends the messages to the Installation Manager in bulk, this scenario optimizes the database updates.
More information:
Behavior of SS Based on Stage Check and Bulk Update Configurations
