To optimize database updates, you must run the scalability server in the bulk update mode. When you configure the scalability server to run only in the bulk update mode, the scalability server handles the messages in the following manner:
Note: In this scenario, where the bulk update mode is enabled and the stage check mode is disabled, the stage check functionality checks only for the unregistered units; it does not send the cached messages. The cached messages (if any) for the registered units are sent during the bulk update.
Note: For more information on the sd_sscmd bulkupdate command, see the bulkupdate section in the Software Delivery CLI Reference Guide.
