Displays a message describing all the dmsweep subcommands and their syntax. This message is also output if the dmsweep command is executed without arguments.
The subcommand has the following format:
help usage
Example:
The following example shows how you can use the dmsweep help command line utility to display subcommands, options, and arguments.
To display the dmsweep command options enter any of the following:
dmsweep dmsweep help dmsweep usage
