The command unlinks a list of specified secured objects from a specified security area.
This command is valid for domain managers only.
It has the following format:
cadsmcmd security action=unlinkSAFromSO
name=security_area_name
{soName=secured_object_name}
classId=security_class_identifier
[folderName=folder_name
folderClassId=identifier_of_the_folder’s_class]
[domainName=domain_name]
Specifies the name of the security area that the specified objects are unlinked from.
Specifies the name (label) of the secured object to be unlinked from the specified security area.
The option can be coded more than once for passing a list of secured objects.
If the secured object is of security class "SoftwarePackage," you have to specify the name and the version in the following format:
«name»|«version».
If «name» contains blanks, you have to enclose «name»|«version» in quotation marks:
"«name»|«version»".
Example:
name testPackage and version 1.0
soname=testPackage|1.0
name CA ITCM Manager and version 12.0
soname="CA ITCM Manager|12.0"
Specifes the identifier of the security class to which the secured objects belong. The following identifiers are valid:
for the software package class
for the software job class
for the software job container class
for the class of software based policies.
Specifies the name of a folder or container to which all the specified secured objects belong. The option is mandatory for the following security classes:
In any other case the parameter is ignored.
Specifies the identifier of the security class to which the folder specified belongs. The following identifiers are valid:
The parameter is ignored whenever the parameter folderName is ignored.
Specifies the name of the domain to which all secured objects specified and possible folders belong. If the parameter is not coded then it is assumed that all objects belong to the local domain of the manager addressed by this CADSMCMD call.
Note: This option is obsolete for security objects of type SoftwarePackage and is ignored when coded.
The following example shows how to unlink the secured object "RAC:srktest" from the security area "m1_area001"
Cadsmcmd security action=unlinkSAFromSO name=m1_area001 soname="RAC:srktest [1/8/2010 12:55PM]" classid=softwarejobcontainer domainname=testdomain
