The parameter -? shows a "Usage" to the user. The usage is also shown if dsmPush is called without parameters, or if there is a severe parameter error. "Usage" is also controlled by the parameter -silent.
dmscript.exe pathname\dsmPush.dms { check <check-parameters> | -? |
copy [-I imagelocation] [<copy-parameters>] [-silent] }
<copy-parameters> =
{ [-single] [<os-parameters>] [<sd/dm-Parameters>] }
[<pack-parameters>] [<lang-parameters>]
<os-parameters> = [-win] [-hp] [-sun] [-ibm] [-linux] [mac] [unixware] <sd/dm-Parameters>= [-REGSD] [-REGDM] <pack-parameters> = [-rc] [-sd] [-am] <lang-parameters> =
[-P nls,enu,chs,deu,esn,fra,jpn,kor] [-L nls,enu,chs,deu,esn,fra,jpn,kor]
<check-parameters> = [-f check-output-file-name]
