Use this action to modify attributes of the manager.
The action has the following syntax:
manager action=modify
[name=manager_name] [newName=new_manager_name] [comment=description_for_manager]
Specifies the name of the manager whose attributes will be modified.
If not coded then the manager is taken with which the CADSMCMD currently is in session.
specifies a new name for the manager.
specifies a new description for the manager.
Note:The manager has to be located in the domain on that the CADSMCMD currently works.
