This action reinstalls a product on a target computer that is already marked as installed.
targetcomputer action=reInstallProduct
name=computer_name
item=item_name
version=item_version
procedure=install_procedure
cname=[name]
[{noLinkage|rollback|synchronized}]
[nocascade]
[deliveryTime="YYYY-MM-DD hh:mm"]
[atTime="YYYY-MM-DD hh:mm"]
after={exacttime|boottime}
[calendarname=delivery_calendar_name]
[preaction={none|reboot|logoff}]
[postaction={none|reboot|logoff|rebootAtEnd|logoffAtEnd|shutdownAtEnd}]
[promptUser[={y|n}]]
[allowCancel[={y|n}]]
[execTimedOut[={y|n}]]
[prompt=days.hours]
[offline[={y|n}]]
[runAtShutdown[={y|n}]]
[preventLogon[={y|n}]]
[globalTime]
[noCalendar]
[parameters=user_parameters]
[jobTimeOut=d.h]
[unsealed]
Start time of the procedure at the target system.
The following values are valid:
The procedure is started immediately after reaching atTime.
The start of the procedure is delayed until the first boot after atTime has been passed.
If "allowCancel" or "allowCancel=y" is coded, the user will be granted to cancel the job's execution.
If "allowCancel=n" is coded, the user will not be granted.
If the parameter is not coded, the default is given by the related procedure's job option value.
If neither promptUser is set by this call nor already enabled, then this parameter is ignored. No warning is given.
Specifies the Specifies the date and time when the action will be started.
The date has the ISO format "YYYY-MM-DD hh:mm".
Specifies the name of the calendar that controls the time when the evaluation can take place.
Specifies an the optional unique name of a job container (default: target_computer_name[YYYY-MM-DD hh:mm:ss]).
It is used for distributing the request. If the container already exists, but is unsealed, it is used without changing its linkage or cascade options. If it exists and is sealed, an error is reported. If it does not exist, the job container will be created according to the linkage and cascade parameters specified.
Specifies the start time of delivery from the domain manager.
If the parameter is not coded, the actual date and time are used.
If "execTimedOut " or "execTimedOut=y" is coded, the job's execution will be automatically started when the user prompt times out.
If "execTimedOut=n", the job will not automatically be started.
If "globalTime" or "globalTime=y" is coded, then the time specifications are based on the enterprise manager time.
If "globalTime=n" is coded, it is based on domain manager time.
Specifies the name of the item to be reinstalled.
Specifies the jobTimeout expiration period of a job in the form “d.h” where d specifies the number of days and h the number of hours. The range of the parameter is configurable at the manager’s site. When the specified value exceeds the configured upper limit then the value is set to the upper limit, if the specified value goes below the lower limit then the lower limit is taken. No warning is given in any case.
jobTimeout should not be coded with the timeout parameter otherwise an error is reported. If none of the parameters is coded the default is given by 7.0.
Specifies the name of the computer where the product should be reinstalled.
If "noCalendar" is coded, a possible calendar at the target computer will be ignored for this job's execution.
The job linkage option is set to "Ignore cascading".
This parameter is allowed only if "transaction" or "synchronized" are coded.
In case of more than one job, this mode handles the linkage between the different jobs of a job container. The coding has the following effects:
Batch job mode used without rollback.
Run the job independently of the other jobs in the container.
Set the job linkage option to "Enable Transaction".
The job linkage option is set to "Synchronized job execution".
If "offline" or "offline=y" is coded, the connection between the target computer and the server will be released for the job's execution and reestablished thereafter.
If "offline=n" the connection will not be released.
Specifies the user parameters for the procedure.
Multiple user parameters must be separated by spaces inside double quotes.
If an empty string is coded, then no parameters are assumed.
Specifies the necessary actions that must take place after completion of the specified procedure. The following values are valid:
Performs no post-action.
Restarts the system after completion of the procedure.
Logs off the user after completion of the procedure.
Restarts the system after completion of all the jobs of this container.
Logs off the user after completion of all the jobs of this container.
Shuts down the target computer after completion of the jobs.
Specifies that necessary actions must take place before the specified procedure starts. The following values are valid:
Performs no pre-action.
Restarts the system before the start of the procedure.
Logs off the user before the start of the procedure.
If "preventLogon" or "preventLogon=y" is coded, then the user logon will be rejected during the job's runtime. If a user is already logged on, the execution of the job is delayed until the user logs off.
If "preventLogon=n" the user logon will not be rejected.
Specifies the name of a procedure
procedure to be used for the reinstallation.
Specifies the time period in which the user will be prompted for the job's start.
The period’s format is "d.h" where d means days and h means hours.
The range of this parameter is from three hours to seven days (from 0.3 to 7.0). If the specified value falls below the valid minimum, the value is replaced by the minimum. If the specified value exceeds the valid maximum, then the value is replaced by the maximum. No warning is given.
If "promptUser" or "promptUser=y" is coded, the user will be prompted for the job's execution.
If "promptUser=n", the user will not be prompted.
If "runAtShutdown" or "runAtShutdown=y" is coded, the job's execution will start at shutdown only.
If "runAtShutdown=n", the job will start at any other time too.
This parameter is for Unix targets only.
The addressed job container remains unsealed after the generated job has successfully been created.
Specifies the version of the item.
The parameters "allowCancel," "execTimedOut" and "prompt" are valid, if the "promptUser" option is already set or is set by this command using the "promptUser" parameter.
If neither the "promptUser" option of a job nor the "promptUser" parameter of the command is set, these parameters will be ignored.
