The CLI provides support for a number of CA IT Client Manager components like Common Objects (CO), Common Configuration (CCNF), Software Delivery (USD), and OS Installation Management (OSIM).
But the CLI only provides this support if the required services are available at the addressed manager. For example, if SD is not installed at the manager then the CLI will not process any command that requires SD or OSIM services but will report an error (CMD000041).
The CLI offers a number of different interfaces the user might use according to solve his/her automation problems. The syntax of the CLI is as follows:
cadsmcmd [local managersystem]
{ batch filename | command | pipe pipename | verbose [loop] }
[login[=loginID[:password]]]
The keywords, commands and parameter names of the CLI are case insensitive but “cadsmcmd” itself. Parameter values might be case sensitive.
The cadsmcmd writes its output to stdout (standard output). It can easily be re-directed into a pipe or file for subsequent processing by a script. When cadsmcmd starts it records some general information on stdout that looks as follows:
CA IT Client Manager r12 ITCM Command Line Version 12.8.0.xxxx Copyright (c) 2013 CA. All rights reserved Trace Mode: Off Connecting to manager “<default manager>” as user “<default user>” … OK. Manager: myManager Domain: myDomain Domain type: Enterprise Supporting CO CCNF USD
The figures in the second line identify the build number of the cadsmcmd. “Trace Mode” line indicates whether the CLI trace is active or not. In this example the trace is inactive. For more information about the CLI trace see below in chapter “The Trace Option”.
The “Connecting” line records how the CLI logs on to the manager. For more details see below in chapters “local” and “login”.
The “Manager” records the name of the manager the CLI is connected to, and the “Domain” presents the name of the system the database is located at. This might be the same name if the database is located at the manager.
The “Domain type” line is indicating the type of manager the CLI is connected to. “Enterprise” means that the manager is an CA ITCM enterprise manager while “Domain” indicates a CA ITCM domain manager.
The last line indicates the support provided by the CLI during the current session.
CO means Common Object support and CCNF means Common Configuration support. As CO and CCNF represents base components of CA ITCM they will always be available.
USD is indicating SD support and OSIM is indicating OS Installation Management support.
The behavior of the CLI depends on the options coded when invoked. The meaning of these options as defined above in the syntax definition will be discussed subsequently in more detail.
This section contains the following topics:
