Previous Topic: ExampleNext Topic: Example
rregsw—Registering Software Remotely
The rregsw command is used to distribute a new software program from the enterprise manager library to a named list of domains or domain groups, and to register it in the library of the domain managers at these domains.
The rregsw command is valid only when issued from the enterprise manager command line.
rregsw  item=item_name
version=version_name
{{area=area_name} | {domain=domain_name} | toAllAreas}
[cname=name]
[sendTime="YYYY-MM-DD hh:mm"]
[haltTime="YYYY-MM-DD hh:mm"]
[delta[={y|n}]]
area
Specifies the name of a CA ITCM domainwhere an item is to be registered.
You can specify this parameter more than once to address a list of CA ITCM domains.
This parameter should not be coded with the domain or toAllAreas parameters.
cname
Specifies the optional, unique name of the distribution.
If no cname parameter is given, a name is generated internally and the command line interface returns this identifier.
delta
Indicates that if the item is based on a previous version, then only the delta should be sent to remote CA ITCM domains. The previous version must already be registered at the remote CA ITCM domains.
domain
Specifies the name of a CA ITCM domain group where the specified item will be registered.
You can specify this parameter more than once to address a list of CA ITCM domain groups.
This parameter should not be coded with the area or toAllAreas parameters.
halttime
Specifies the date and time at which a distribution order should be halted. The date has to be specified in the ISO format "YYYY-MM-DD hh:mm".
For more information about resuming a halted distribution, see the resume command.
item
Specifies the name of the item being deregistered.
sendtime
Specifies the time to send the associated distribution to the addressed domain managers. The date has to be specified in the ISO format "YYYY-MM-DD hh:mm". If the parameter is not coded, the actual date and time is used.
toAllAreas
If coded the related distribution will be sent to all CA ITCM domains registered at the enterprise manager.
"toAllAreas" should not be coded with the "area" or "domain" parameters.
version
Specifies the version of the item being registered.
