This command is used to resume a halted distribution.
It has the following format:
resume name=jobcontainer_name
[sendtime="yyyy-mm-dd hh:mm" ] [halttime="yyyy-mm-dd hh:mm" ]
Specifies the date and time at which a distribution order should be halted. The date has to be specified in the ISO format "YYYY-MM-DD hh:mm".
Note: Max_Dist_Time determines the maximum number of minutes that can elapse before a container distribution is set to an error state.
Specifies the name of the distribution that is halted and has to be resumed.
Specifies the time to send the associated distribution to the addressed domain managers. The date has to be specified in the ISO format "YYYY-MM-DD hh:mm". If the parameter is not coded, the actual date and time is used.
