This action allows you to delete a planned configuration.
If the system is OSIM managed and if there is a planned OS installation order, then this planned OS installation is deleted. In any other case, the request will fail.
If the planned configuration to be removed is the only configuration associated with the specified system the system will become OSIM unmanaged.
targetComputer action=deletePlannedOS
name=computer_name
Specifies the name of the computer of which an existing planned configuration will be deleted.
