This action displays a list of targets known to the system.
An additional filter can be specified to restrict the list to only those targets that fulfill the filter criteria. If no filters are given, the complete list of targets is shown.The filter is limited to 100 bytes.
Note: The filter usage of This action differs from that of other commands.
targetcomputer action=list
[{filter=filter|filterfile=file_name}]
[{DisHwOnly | usrProfOnly | UnMgdPcOnly}]
Specifies the expression to confine the amount of information listed
The following attributes are valid to build atomic filter expressions:
Attribute |
Type |
Compare ops |
Computer name |
string |
Computer type |
{ computer | |
Host name |
string |
Primary network address |
string |
IP address |
string |
Operating system type |
any valid os type of the os parameter of the create action |
Calendar name |
string |
Owner |
string |
Phone |
string |
Location |
string |
Comment |
string |
staging server name |
string |
Software managed system |
{ yes | no } |
RAC policy |
{ automatic | |
Creation date |
YYYY-MM-DD hh:mm:ss |
Change date |
When building a filter, the attribute names in the atomic expressions are case insensitive.
YYYY-MM-DD hh:mm:ss means a date and time notation in ISO format.
The values for attributes of type string may contain wildcards,
“*” or “?”, where “*” represents an arbitrary even empty string of characters, while “?” represents a single but arbitrary character. If a “*” or “?” should not be interpreted as a wildcard then it should be preceded by an apostrophe (‘). In order to avoid ambiguity, apostrophes as part of the attribute value should be duplicated.
Specifies the name of the file that contains the filter commands.
The commands in the file are specified in the same way as in the filter parameter, but the size of the file is limited by the capacity of the system that runs this command..
These options are used to restrict the search on information the user is interested in. If not coded a list of computer, user profiles, scalability servers, docking devices, and OSIM un-managed computers is provided and all related database tables are searched.
The list is restricted to registered hardware like computers, scalability servers and docking devices.
The list is restricted to user profiles only
The list is restricted to OSIM un-managed computers only.
