This command creates a local software policy based on the specified options. You can optionally link the software policy to a local or a global computer group and populate it with jobs during the creation phase. If you are able to link and populate the policy successfully, you can also seal it.
swPolicy action=create
name=software_policy_name
[target=computer_group_name
[groupScope={local|global}]]
[seal[={y|n}]]
[{group=name_of_a_software_or_procedure_group|
procedures=job_file}]
[jcPriority=1…10]
[{transaction|synchronized|nolinkage}]
[rollback[={y|n}]]
[cascade[={y|n}]]
[{setup_jobs|setup&activate_jobs}]
[regenerate[={y|n}]]
[evaluateGroup[={y|n}]]
[evaluationStart=YYYY-MM-DD hh:mm]
[globalTime[={y|n}]]
[evaluationPeriod=hours]
[calendarname=calendar_name]
[{adhoc_only|adhoc_always}]
[comment=comment_on_software_policy]
[userMessage]
The name of the software policy created is specified with this option. This name has to be unique.
The name specified with this option is the name of a computer group the software policy will be linked to. The computer group must already exist. It can either be a global group at the enterprise manager or a local or global group at the domain manager.
If this option is not coded then the software policy to be created is not linked to any computer group.
Determines the type of computer group being linked to the software policy:
If there is a local computer group of the specified name then this one is taken, otherwise it is looked for a global one.
The computer group has to be a local group.
The computer group has to be a global group.
If “seal” or “seal=y” is coded then the created policy is sealed otherwise it remains unsealed for further modifications.
The seal option is only allowed when the policy is linked and populated with the creation and it is only processed if the link and population has been successful.
This option specifies the name of a software or procedure group. The members of the group are used to populate the software policy during the creation process with jobs.
The jobs of the policy are generated from the default installation procedures of the group members, if there are any, or from the first installation procedure in order. The job options are taken from the defaults or are inherited from the procedure.
The jobs for the policy are generated from the procedures of the group. The job options are taken from the defaults or are inherited from the procedure.
If this option is not coded no groups are evaluated for populating the created software policy.
The group option should not be coded with the procedures option.
This option specifies the name of a file that contains the information for generating the jobs for the software policy. For each job to be generated and assigned to the policy an entry of the following syntax has to be created in the file:
item=item_name version=item_version
procedure=procedure_name
task={activate | configure | install | uninstall}
[installedWith=install_procedure_name]
[after={exacttime | boottime}]
[reinstall={y|n}]
[preaction={none | reboot | logoff}]
[postaction={none | reboot | logoff | rebootAtEnd | logoffAtEnd | shutdownAtEnd}]
[promptUser={y|n}]
[allowCancel={y|n}]
[execTimedOut={y|n}]
[offline={y|n}]
[runAtShutdown={y|n}]
[preventLogon={y|n}]
[triggeredByScalSrv={y|n}]
[globaltime={y|n}]
[calendarname=delivery_calendar_name]
[noCalendar={y|n}]
[resolveQuery={y|n}]
[stagingServer={y|n}]
[parameters=user_parameters]
[prompt=d.h]
[jobTimeout=d.h]
[repeat={y|n}]
There should be only one entry per line and an entry should not span over more than one line. The entry has to begin with the parameters “item”, “version”, “procedure” and “task” and they have to appear in this sequence. The order of the remaining parameters is arbitrary. Parameter values containing blanks should be enclosed in quotes (“). If a parameter value contains a quote it should be duplicated.
For the meaning of the parameters please have a look at “cadsmcmd swPolicy action=addItem”.
The procedures option should not be coded with the group option.
This option specifies the job container priority used by the policy to create a job container for launching its SD orders. A valid priority is one of the values 1, 2, 3, 4, 5, 6, 7, 8, 9, 10. 10 is the lowest priority and 1 is the highest. If the option is not coded the priority 5 is set.
This option specifies the job linkage within the job container created by the policy for launching the SD orders.
No linkage between orders.
Batch job execution without transaction.
Synchronized job execution.
No linkage between the orders.
If the option “rollback” or “rollback=y” is coded then the job linkage is set to "Enable Transaction". If the option is coded as “rollback=n” then “Enable Transaction” is not set.
Default is “rollback=n”.
The parameter should only be coded if parameter "transaction" is coded with this command.
If the option “cascade” or “cascade=y” is coded then the SD will resolve the dependencies of cascaded installation request and add the missing installation orders automatically. If the option is coded as “cascade=n” then the dependency is not resolved.
Default is “cascade”.
This option drives the results of the policy’s evaluation:
The SD checks only for conformity while evaluating the policy and reports the non conform targets but no jobs are generated for transferring the non conformant targets into conformant.
As a result of the evaluation the SD generates jobs for transferring all non conformant targets into conformant ones but these jobs are not launched for execution. The latter is left to the user.
As a result of the evaluation the SD generates jobs for transferring all non conformant targets into conformant ones and launches them for execution.
If the option “regenerate” or “regenerate=y” is coded then all jobs that failed earlier and have not been completed successfully yet are rescheduled for execution for achieving conformity. If the option “regenerate=n” is coded then this rescheduling is skipped.
Default is “regenerate”.
If the option “evaluateGroup” or “evaluateGroup=y” is coded then in case of a query group associated with the policy this group will be re-evaluated during the policy’s evaluation too. If “evaluationGroup=n” is coded then this re-evaluation of the group will not happen.
Default is “evaluateGroup=n”.
This option specifies the earliest point in time when the evaluation of the policy will start. The value is specified in ISO format “YYYY-MM-DD hh:mm” where YYYY specifies the year, MM the month, DD the current day of month, hh the hour and mm the minute. If this option is not coded the current time is taken.
This option specifies whether the time specifications with the policy are based on enterprise time or domain time. If this option is coded then the time is enterprise base otherwise it is domain time.
This option specifies the period the evaluations of the policy takes place. The value is specified in hours. If 0 is specified then the evaluation happens only once.
This option specifies the name of the calendar used by the SD for scheduling the time driven actions of the policy.
This option specifies whether SD evaluates this policy when a target reports its inventory or not and it specifies the mode of processing:
The policy evaluation is not initiated by any target inventory reports.
The evaluation is started by inventory reports of new or re-installed targets.
The evaluation is started by any inventory reports from targets.
The option specifies a comment that is stored with the policy.
Specifies the custom administrator message for a software policy.
Note: You should be aware of the following:
