Previous Topic: Job Management CommandsNext Topic: Example
addJob—Add Job to Job Container
This command adds a job to an existing job container. You must not seal the job container.
jobcontainer action=addjob
name=job_container_name
{item=item_name version=item_version
procedure=procedure_name
{[task=install]
|task={configure|activate|uninstall}
[installedWith=install_procedure]}
| group=group_name [procedures=file]}
{{{compgrp=computer_group_name | ccompgrp=(computer_group_name sep groupScope)}
[sep=separator_sign]
|{computer=computer_name}}
[deliverytime="YYYY-MM-DD hh:mm" ]
[attime="YYYY-MM-DD hh:mm" ]
[{preaction={none|reboot|logoff}|bootbefore}]
[{postaction={none|reboot|logoff|rebootAtEnd|logoffAtEnd|shutdownAtEnd}|bootafter}]
[promptUser[={y|n}]]
[allowCancel[={y|n}]]
[execTimedOut[={y|n}]]
[offline[={y|n}]]
[runAtShutdown[={y|n}]]
[preventLogon[={y|n}]]
after={exacttime|boottime}
[calendarname=delivery_calendar]
[globalTime=y|n]
[nocalendar[={y|n}]]
[resolveQuery[={y|n}]]
[stagingServer[={y|n}]]
[parameters=user_parameters]
[prompt=days.hours]]
[jobTimeOut=days.hours]
[reinstall[={y|n}]]
[userJobMessage]
after
Start time of the procedure at the target system.
The following values are valid:
exacttime
The procedure is started immediately after reaching atTime.
boottime
The start of the procedure is delayed until the first boot after atTime has been passed.
allowCancel
If "allowCancel" or "allowCancel =y" is coded, the user will be granted to cancel the job's execution.
If "allowCancel =n" is coded, the user will not be granted.
If the parameter is not coded, the default is given by the related procedure's job option value.
atTime
Specifies the date and time when the action will be started.
The date has the ISO format "YYYY-MM-DD hh:mm".
If the parameter is not coded, the actual date and time are used.
calendarname
Specifies the name of the calendar that controls the time when the evaluation can take place.
ccompgrp
Specifies the computer group to be addressed as a pair of group name and scope. By default, name and scope are separated by a dot ("."), but an alternate separator can be specified with the "sep" option. The separator should not be used as part of the names.
For the group scope only the following values are valid.
local
The group is created at the local domain manager,
global
The group has been created at the enterprise manager and may be replicated.
The "ccompgrp" can be coded with the "compgrp" in one call.
compgrp
Specifies the name of a computer group on which the specified product will be processed.
The parameter can be coded more than once to address more than one computer group.
The parameter must not be coded together with the computer parameter.
computer
Specifies the name of the computer on which the specified product will be processed.
The parameter can be coded more than once to address more than one computer.
The parameter must not be coded together with the compgrp parameter.
deliveryTime
Specifies the start time of delivery from the domain manager.
execTimedOut
If "execTimedOut " or "execTimedOut=y" is coded, the job's execution will be automatically started when the user prompt times out.
If "execTimedOut=n", the job will not automatically be started.
globalTime
If "globalTime" or "globalTime=y" is coded, then the time specifications are based on the enterprise manager time.
If "globalTime=n" is coded, it is based on domain manager time.
group
Specifies the name of a software or procedure group the jobs will be generated for.
The parameter must not be coded together with the item parameter.
installedWith
Specifies the name of the install procedure.
This parameter is mandatory for the tasks configure, activate, and uninstall. Otherwise it is ignored.
item
Specifies the name of the item to be processed.
This parameter must not be coded together with the group parameter.
jobTimeOut
Specifies the expiration date of the job in form of a period.
The period is specified in the format "d.h" where d means days and h means hours.
The range of this parameter is from three hours to seven days (from 0.3 to 7.0).
If the specified value falls below the valid minimum, the value is replaced by the minimum.
If the specified value exceeds the valid maximum, then the value is replaced by the maximum.
No warning is given.
name
Specifies the name of the job container to which the job will be added.
noCalendar
If "noCalendar" is coded, a possible calendar at the target computer will be ignored for this job's execution.
offline
If "offline" or "offline =y" is coded, the connection between the target computer and the server will be released for the job's execution and reestablished thereafter.
If "offline =n" the connection will not be released.
parameters
Specifies the user parameters for the procedure.
Multiple user parameters must be space separated inside double quotes.
If an empty string is coded, then no parameters are assumed any longer.
postaction
Specifies that necessary actions must take place after the specified procedure has terminated. The following values are valid:
none
Performs no post-action.
reboot
Restarts the system after completion of the procedure.
logoff
Logs off the user after completion of the procedure.
rebootAtEnd
Restarts the system after completion of all jobs of this container.
logoffAtEnd
Logs off the user after all completion of all jobs of this container.
shutdownAtEnd
Shuts down the target computer after completion of the jobs.
preaction
Specifies that necessary actions must take place before the specified procedure starts. The following values are valid:
none
Performs no pre-action.
reboot
Restarts the system before the start of the procedure.
logoff
Logs off the user before the start of the procedure.
preventLogon
If "preventLogon" or "preventLogon =y" is coded, then the user logon will be rejected during the job's runtime. If a user is already logged on, the execution of the job is delayed until the user logs off.
If "preventLogon =n" the user logon will not be rejected.
procedure
Specifies the name of a procedure
procedures
Specifies the name of the file defining the procedures to be used for the software group and / or to define individual job options for the procedures (software and procedure groups).
For the content of this procedures file, see Procedures File Format
prompt
Specifies the time period in which the user will be prompted for the job's start.
The period’s format is "d.h" where d means days and h means hours.
The range of this parameter is from three hours to seven days (from 0.3 to 7.0). If the specified value falls below the valid minimum, the value is replaced by the minimum. If the specified value exceeds the valid maximum, then the value is replaced by the maximum. No warning is given.
promptUser
If "promptUser" or "promptUser=y" is coded, the user will be prompted for the job's execution.
If "promptUser=n", the user will not be prompted.
reinstall
Optional. Default: “reinstall=n”
If “reinstall” or “reinstall=y” is coded then a possible installation record related to the order is removed before the job is evaluated by the domain manager.
If “reinstall=n” is coded then such records will remain.
Note: Option only applies to install jobs. In any other cases it is ignored.
resolveQuery
Evaluate a possibly related query group before the job is generated.
runAtShutdown
If "runAtShutdown" or "runAtShutdown=y" is coded, the job's execution will start at shutdown only.
If "runAtShutdown=n", the job will start at any other time too.
This parameter is for Unix targets only.
sep
Specifies an alternate separator used with the "ccompgroup" option. The separator should not be part of the group name code with the "ccompgroup" options.
stagingServer
Deliver the related product also to the staging libraries of the scalability servers of the target computers.
This parameter applies to procedures of task type "install" only!
task
Specifies the type of task to be performed by the item procedure.
The following types are valid:
activate
The procedure activates the item.
configure
The procedure configures the item.
install
The procedure installs the item.
uninstall
The procedure uninstalls the item.
If the parameter is not coded, install is assumed.
version
Specifies the version of the item to be processed.
userJobMessage
Specifies the custom administrator message for a job in a job container.
Note: You should be aware of the following:
The procedures file consists of entries of the following syntax:
item = item
version = version
procedure = procedure
task={install|configure|activate|uninstall}
[after={exacttime|boottime}]
[calendarname=deliverycalendar]
[preaction={none|reboot|logoff}]
[postaction={none|reboot|logoff|rebootAtEnd|logoffAtEnd}]
[promptUser={y|n}]
[allowCancel={y|n}]
[execTimedOut={y|n}]
[prompt=days.hours]
[offline={y|n}]
[RunAtShutdown={y|n}]
[PreventLogon={y|n}]
[GlobalTime={y|n}]
[nocalendar={y|n}]
[ResolveQuery={y|n}]
[Parameters=userparameter]
[stagingserver={y|n}]
[JobTimeout=d.h]
item
Name of the group item this entry is related to
version
Version for the group item this entry is related to
procedure
Specifies the item procedure to be performed
task
Specifies the procedure type.
install
configure
activate
uninstall
The parameters "item", "version", "procedure", and "task" have to be coded at each line as the first parameters and they have to be coded in the order as in the syntax definition previously shown. The remaining parameter can be coded in any order.
The meaning of the other parameters corresponds to the meaning of the command parameters shown in cadsmcmd jobcontainer action=addjob.
The procedure options for a job procedure are taken from the settings in this list.
If for a procedure an option is not coded in the related list entry then it is taken from the settings on command layer.
If it is not coded there then it is taken from the procedure options registered.
