Previous Topic: dsmPush ExamplesNext Topic: MDB Admin Console CLI
intellisigcmd - Command Line Tool
intellisigcmd is a command line tool for Intellisigs. This tool has the following format:
intellisigcmd <cmd> param1=value1 param2=value2 ... [<DB_Credentials>]
cmd
Specifies the import, export, or genuuid command.
DB_credentials
Specifies the database credentials of the MDB. By default, the credentials are retrieved from the comstore.
Use the following sample format to specify the DB credentials:
Example: SQLServer DB Credentials format
dbvendor=mssql dbhost=myhost dbname=mdb dbuser=ca_itrm dbpassword=mypwd dbinstance=inst
Example: Oracle DB Credentials format
dbvendor=oracle dbhost=myhost dbname=orcl dbuser=ca_itrm dbpassword=mypwd dbinstance=1521
intellisigcmd export—Export Intellisigs
The intellisigcmd export command lets you export Intellisigs.You can either use the DSM Explorer or use the command to export Intellisigs.
intellisigcmd export file=<export name> [type=xml|zip] [platform=all|windows|unix]
export name
Specifies the name of the Intellisig XML or zip file that you want to export. If you do not provide the file extension, and the type is xml, the command creates a folder with the supplied name.
type
Specifies whether you want to export an XML or zip file. If you do not include the type parameter, the command assumes the export type depending on the export file extension.
Valid values: xml, zip
platform
Specifies the platform to determine which Intellisigs are exported.
Valid values: all, windows, unix
Default: all
intellisigcmd import—Import Intellisigs
The intellisigcmd import command lets you import Intellisigs.You can either use the DSM Explorer or use the command to import Intellisigs.
intellisigcmd import [file=<import source>] [type=xml|zip] [mode=replace|mergenew|mergeall] [updateactive=yes|no] [delete=yes|no]
import source
Specifies the name of the XML or zip file to which you want to import the Intellisig. If you do not provide the file extension, the command assumes the file extension depending on the type.
Note: If you want to import to an XML file, verify that the supporting directories exist in the same folder as the XML file.
type
Specifies whether you want to import as XML or zip file. If you do not include this parameter, the command assumes the import type depending on the import file extension.
mode
Specifies the import mode. Following import modes are supported:
Default: mergenew
replace
Replaces existing definitions with the definition being imported. Existing definitions are lost.
mergenew
Appends new Intellisig versions to the definitions on the manager. Existing definitions are not modified.
mergeall
Appends new Intellisig versions and updates the existing definitions that are included in the import file. Intellig versions that are not defined in the import files are not modified.
updateactive
Specifies whether active Intellisig versions can be updated during the import.
Valid values: Yes, Y, true, 1 or No, N, false, 0
Default: Yes
delete
Specifies whether you want to delete Intellisigs before the import. If you do not include the delete switch, none of the Intellisigs are deleted before import.
Default: No
intellisigcmd genuuid—Generate UUIDs
The intellisigcmd genuuid command lets you generate unique UUIDs which you can use when creating custom Intellisigs.
intellisigcmd genuuid [num=<count>]
num
Specifies the number of UUIDs to be generated. If you do not specify this parameter, a single UUID is generated. Otherwise, <count> UUIDs are generated.
Valid Values: 1 to 1000
