This action will export the specified product to the specified location.
swlibrary action=export
item=item_name version=item_version path=path_name [onserver] [as_image]
If coded the software will be exported to a library image that can be used by the Software Management Installer to grab packages from a CD.
Specifies the name of the product to be exported.
Specifies the version of the product to be exported.
Specifies the destination where the exported product is stored. The directory must be empty.
If it is coded, the destination is settled on the manager, otherwise not.
