This action deletes a parameter.
comconf action=deleteParm
name=policy_name,pType=policy_type parmsec=parameter_section_name parameter=parameter_name
Specifies the name of the policy the parameter is removed from.
Specifies the type of the policy the parameter is removed from.
Specifies the parameter section the parameter is removed from. The section is absolute section path from the policy's root of format "/section_1/section_2/section_3".
The section names can either be taken from the detailed output of the showPolicy action or from the Internal Name column of the CA ITCM Explorer.
Specifies the name of the parameter to be removed.
