Previous Topic: ParametersNext Topic: Example
setParm—Set a Parameter and Value
This action allows to set a parameter and value.
comconf action=setParm
name=policy_name,
pType=policy_type
parmsec=parameter_section_name
parameter=parameter_name
value=parameter_value
policy
Specifies the name of the policy the parameter belongs to.
pType
Specifies the type of the policy the parameter belongs to.
parmsec
Specifies the parameter section the parameter belongs to.
The section is absolute section path from the policy's root of format "/section_1/section_2/section_3".
The section names can either be taken from the detailed output of the showPolicy action or from the Internal Name column of the CA ITCM Explorer.
If the section specified is not existent at the specified policy then it is created if the section exists at the default policy too.
parameter
Specifies the name of the parameter to be set.
If the parameter is not available at the specified parameter section but at the same section at the default policy then it is created.
value
Specifies the new value of the parameter.
