Previous Topic: Configure LoggingNext Topic: cadsmcmd Messages
Error Messages
MDB Admin Console returns the following error messages when it is unable to process a request:
MDBAC-0=[MDBAC-0] no error detected
MDBAC-1=general command line error.
MDBAC-2=command line error
MDBAC-3=business class name unknown
MDBAC-4=no working folder given
MDBAC-5=internal error: the business class does not support the IBOExport interface
MDBAC-6=configuration/connection not found
MDBAC-7=input file not found
MDBAC-101=[MDBAC-101] feature is not supported at this level of implementation
MDBAC-102=[MDBAC-102] internal error: no import interfaces found
MDBAC-103=[MDBAC-103] unable to create database session
MDBAC-104=[MDBAC-104] cannot create Object
MDBAC-105=[MDBAC-105] Stored procedure for pushing data failed
MDBAC-106=[MDBAC-106] constrain violation during import
MDBAC-107=[MDBAC-107] verification of target schema failed
MDBAC-108=[MDBAC-108] failed to generate transaction id
MDBAC-109=[MDBAC-109] illegal XML file format detected during import/view
MDBAC-110=[MDBAC-110] failed to read name ids form the database
MDBAC-111=[MDBAC-111] failed to transform business object
MDBAC-112=[MDBAC-112] failed to import inventory name ids
MDBAC-113=[MDBAC-113] one or more files are failed during import of a folder
MDBAC-114=[MDBAC-114] cannot create connection to source database
MDBAC-115=[MDBAC-115] cannot create connection to source database
MDBAC-116=[MDBAC-116] connection name not found
MDBAC-117=[MDBAC-117] database type no supported
MDBAC-118=[MDBAC-118] illegal connection configuration, failed to setup a configuration to connect to the database
MDBAC-119=[MDBAC-119] error detected when reading the data from the database
MDBAC-120=[MDBAC-120] not all objects are exported, one or more object failed to get it exported
MDBAC-121=[MDBAC-121] deletion of one or more business objects failed
MDBAC-125=[MDBAC-125] database connection does not exists
MDBAC-126=[MDBAC-126] failed to adjust MDB configuration.
MDBAC-127=[MDBAC-127] connection name not found in properties file containing the adjust rule
MDBAC-128=[MDBAC-128] failed to adjust manager with MDB
MDBAC-129=[MDBAC-129] adjust properties file does not exist
MDBAC-201=[MDBAC-201] missing one or more command line arguments
MDBAC-202=[MDBAC-202] configuration undefined
MDBAC-203=[MDBAC-203] configuration file/name not found
MDBAC-204=[MDBAC-204] missing SQL file
MDBAC-205=[MDBAC-205] SQL folder does not exist
MDBAC-206=[MDBAC-206] SQL file does not exist
MDBAC-207=[MDBAC-207] missing name of database user
MDBAC-208=[MDBAC-208] missing password of the database user
MDBAC-209=[MDBAC-209] cannot connect to database
MDBAC-210=[MDBAC-210] command aborted
MDBAC-211=[MDBAC-211] error in SQL script
MDBAC-212=[MDBAC-212] creation of tables failed to extend the target schema
MDBAC-213=[MDBAC-213] failed to delete the target schema extension
MDBAC-214=[MDBAC-214] failed to verify the target schema extension
MDBAC-215=[MDBAC-215] failed to align the collation settings of the target schema extension
MDBAC-216=[MDBAC-216] failed to create target schema
MDBAC-217=[MDBAC-217] failed to align target schema, schema configuration problem
MDBAC-218=[MDBAC-218] session exists but failed to read connection information
MDBAC-219=[MDBAC-219] failed to export data via CcnfRegDb command
MDBAC-220=[MDBAC-220] CcnfRegDb command not found
MDBAC-221=[MDBAC-221] failed to import data via CcnfRegDb command
MDBAC-222=[MDBAC-222] policy data not found
MDBAC-223=[MDBAC-223] Security profile rejected. Security profile of this type is disabled
MDBAC-224=[MDBAC-224] Software definition rejected. Software definition of this type is disabled
MDBAC-225=[MDBAC-225] Warning: not all matched objects are exported
MDBAC-227=[MDBAC-227] Save or Update of an database object(s) failed
MDBAC-228=[MDBAC-228] failed to read database object(s)
MDBAC-229=[MDBAC-229] creation of database user failed
