The export method exports MDB objects from a source MDB. It creates an XML file for each object that matches the specified object name or pattern. The XML files are named as follows:
ObjectType__ObjectName__(counter).xml
Example: XML file name
BoQueryDef__Asset is a Virtual Machine - MS Virtual PC__(1).xml
mdbac.bat -export MDB_Object_Type -name Object_Name - work workfolder -source Connection_Name {-user User_Name -pwd Password | -wallet wallet_file_name}
Specifies the MDB object type that you want to export.
Note: For a list of supported MDB object types, see the "Supported MDB Object Types" appendix.
Specifies the object name in the given object type that you want to export. You can use wildcard characters to match a pattern. For example, you can specify "Asset%" to process all the objects that start with the name "Asset" in the given object type.
Example: Export MDB Objects
This example command exports queries that start with the object name "Asset is a Virtual Machine" from a specified SQL MDB:
mdbac.bat -export BoQueryDef -name "Asset is a Virtual Machine%" -work C:\TEMP\work -source mssql -user ca_itrm -pwd password123
Example: Using the Wallet Argument
mdbac.bat -export BoQueryDef -name "Asset is a Virtual Machine%" -work C:\TEMP\work -source mssql -wallet dbwallet
