You can use MDB Admin Console to export and import data in the following scenarios:
CA ITCM r12.5, or r12.8 to equivalent or higher versions of CA ITCM
You can export the MDB Objects from a CA ITCM r12.5, or r12.8 MDB and import them into the MDB of an equivalent or higher version of CA ITCM. For example, you can export the MDB objects from a CA ITCM r12.5 MDB and import them into a CA ITCM r12.8 MDB.
Enterprise to Enterprise
You can export the MDB Objects from a DSM enterprise manager MDB and import them into another CA ITCM enterprise manager MDB.
Domain to Domain
You can export the MDB Objects from one domain manager MDB and import them into another domain manager MDB.
SQL Server to Oracle
You can export the MDB Objects from a SQL Server MDB and import them into an Oracle MDB. Similarly, you can export the MDB Objects from an Oracle MDB and import them into a SQL Server MDB.
Note: You can combine the export and import scenarios. For example, you can export the MDB Objects from a CA ITCM r12.5 enterprise manager MDB and import into a CA ITCM r12.8 enterprise manager MDB.
