Suppose a software template is needed that meets the following requirements:
The following command will create this group:
cadsmcmd templateGroup action=create name=tgg transaction cascade "setup&activate_jobs" query="Target.Address MATCHES '172.16.213.*' AND (Target.OS='Win NT Intel' OR Target.OS='Win 2000 Intel' OR Target.OS='Win XP Intel')" evaluationPeriod=48 calendarName=tgCal
To control the actual list of software template , the following command lists all software template defined at the server:
cadsmcmd templateGroup action=list
CA IT Client Manager r12 ITCM Command Line Version 12.8.0.xxxx Copyright (c) 2013 CA. All rights reserved. Trace mode: Off Connecting to manager "<default manager>" as user "<default user>" ... ok. Manager: mymanager Domain: mydomain Domain type: Domain Supporting: CO CCNF USD OSIM ------------------------------------------------------------------------------- List of template groups ------------------------------------------------------------------------------- TG_KKKKK01A (local, query) tgg (local, query) tgs (local) tg (local) ------------------------------------------------------------------------------- Number of software templates found: 4 SDCMD<A000000>: OK
For controlling the attributes of the created software template the following command will return the attribute settings of the group:
cadsmcmd templateGroup action=showAttr name=tgg
CA IT Client Manager r12 ITCM Command Line Version 12.8.0.xxxx Copyright (c) 2013 CA. All rights reserved. Trace mode: Off Connecting to manager "<default manager>" as user "<default user>" ... ok. Manager: mymanager Domain: mydomain Domain type: Domain Supporting: CO CCNF USD OSIM ------------------------------------------------------------------------------- Show attributes of template group "tgg" ------------------------------------------------------------------------------- Name of template.group.................: tgg Group type.............................: Query/Template group Scope..................................: Local Query..................................: USD_tgg [04/09/05 13:53:49.916] Comment................................: Engine name............................: <All Engines> Engine Period (minutes)................: 1 Creation date..........................: 2005-04-09 Creation time..........................: 13:53 Change date............................: 2005-04-09 Change time............................: 13:53 Name of template.......................: tgg [$date $time] ..Scope................................: Local ..State................................: Diabled ..Job container priority...............: 5 ..Sealed...............................: No ..Comment..............................: ..Properties of the template...........: 148 .........................................Transaction .........................................Cascade install .........................................Job setup and activation in case of nonc .........................................+ onformity Calendar name..........................: tgCal Evaluation period......................: 48 Next evaluation date...................: 2005-04-09 Next evaluation time...................: 13:32 Last evaluation date...................: 2005-04-09 Last evaluation time...................: 13:53 Evaluation type mask...................: 196609 .........................................Periodical .........................................Query evaluation .........................................Template evaluation SDCMD<A000000>: OK
