Normally target systems are introduced to the SD servers when they are installing the agent and running the first job check. By this way the new system can only be addressed with software packages when they have been registered from the network.
Sometimes it is better to provide the software for the new systems in advance. Therefore, the new systems have to be added manually to the manager’s database.
As soon as they are added they can be taken into account for software templates or job delivery. Nevertheless, the job deliveries will work first when the systems has been registered from the network.
Now assume the system "newComp" should be manually created at the manager and it should meet the following requirements:
The system is attached to the scalability "stage_01".
The following command will introduce this system to the server:
cadsmcmd targetcomputer action=create name=newComp address=newComp.myCompany.com os=WIN_XP_INTEL computerType=machine softwareManagedSystem stagingServer=stage_01
