The following example shows how the regsw command would be issued from a Linux server to register version 0.45 of a software package called "Software Test".
cadsmcmd regsw item="Software Test" version=0.45 path=/usr/test/swtest1 comment="Test software registration" supplier=CA procedures=/usr/test/proclist.txt
The following example illustrates how to register the same software package from a Windows server, and includes four embedded item procedures. The procedures parameter provides the name of the file where the procedures are listed.
cadsmcmd regsw item="Software Test" version=0.45 path=c:\test\swtest1 comment="Test software registration"supplier=CA procedures=c:\test\proclist.txt
Following is a sample file containing a list of procedures:
# This file contains a list of all embedded item procedures for Software Test, Version 0.45
regproc task=install procedure="Install Proc 1" os=WINDOWS_32-BIT type=command enduser file=install1.cmd path=\
regproc task=activate procedure="Activate Proc 1" os=WINDOWS_32-BIT type=command enduser file=activ1.cmd path=\
regproc task=configure procedure="Configure Proc 1" os=WINDOWS_32-BIT type=command enduser file=config1.cmd path=\
regproc task=uninstall procedure="Uninstall Proc 1" os=WINDOWS_32-BIT type=command enduser file=uninst1.cmd path=\
The path is "\", because the procedures reside in the same directory as the software itself. If the procedures resided in the subdirectory "C:\test\swtest1\proc", then "path=\proc" should have been used in the procedures file. Path is defined in the same manner on Linux servers, with the obvious change of directory separator to "/".
