To retrieve detailed information about the job "prod 3 1.0:inst" related to the target KKKKK01B, enter the following command:
cadsmcmd jobContainer action=showJobDetails name="myContainer" jobName="prod 3 1.0:inst" destination=KKKKK01B
CA IT Client Manager r12 ITCM Command Line Version 12.8.0.xxxx Copyright (c) 2013 CA. All rights reserved. Trace mode: Off Connecting to manager "<default manager>" as user "<default user>" ... ok. Manager: mymanager Domain: mydomain Domain type: Domain Supporting: CO CCNF USD OSIM ------------------------------------------------------------------------------- Details for job "prod 3 1.0:inst" to ........."KKKKK01B" of "myContainer" ------------------------------------------------------------------------------- Comment................................: Job container status...................: failed Job container properties...............: 9 .........................................No linkage .........................................Rollback previous jobs on failure Sealed.................................: Yes Creation date..........................: 2005-04-12 Creation time..........................: 08:30 Change date............................: 2005-04-12 Change time............................: 12:16 Number of contained objects............: 4 Job name...............................: prod 3 1.0:inst Overall state..........................: ERROR .........................................0 - waiting .........................................0 - active .........................................1 - ok .........................................1 - failed ..Job order number.....................: 1 ..Creation date........................: 2005-04-12 ..Creation time........................: 10:57 ..Delivery date........................: 2003-04-12 ..Delivery time........................: 10:49 ..Activation date......................: 2005-04-12 ..Activation time......................: 10:49 ..Delivery calendar....................: ..Timeout <days/hours>.................: 7 / 0 ..Job startup..........................: local time/exact ..Job permission.......................: 7 .........................................renew allowed .........................................cancel allowed .........................................recover allowed ..Pre action............................: no action ..Post action...........................: no action ..Job operation mask...................: 134 .........................................prompt user .........................................calendar controlled .........................................Repeat for every evaluation ..User parameters......................: ..Job execution mode...................: 1 .........................................execute ..Prompt timeout <days/hours>..........: 1 / 0 ..Job task.............................: 1 - install ..Targetsystem.........................: KKKKK01B ....Task...............................: 1 .........................................install ....Procedure name.....................: inst ....Ordered by.........................: KKKKK01 ....Job state..........................: EXECUTION_ERROR ....Error message......................: Exit code 2 indicates possible error ....Error cause........................: 228001 ....Comment............................: ....Computer installation procedure....: inst ....Activation date....................: 2005-04-12 ....Activation time....................: 10:49 ....Creation date......................: 2005-04-12 ....Creation time......................: 12:16 ....Completion date....................: 2005-04-12 ....Completion time....................: 12:16 ....Data sent in per cent..............: 100 SDCMD<A000000>: OK
Note: If the job presented is a reinstallation job, there will be a corresponding entry in the output (after "Job operation mask"), otherwise the line is missing.
