Previous Topic: showAttrJobs—Show Job AttributesNext Topic: showJobDetails—Show Job Details
Example
To see the attributes associated with job "prod 3 1.0:inst" of "myContainer" enter the following command:
cadsmcmd jobContainer action=showAttrJobs name="myContainer" jobName="prod 3 1.0:inst"
The output will be as follows:
CA IT Client Manager r12
ITCM Command Line Version 12.8.0.xxxx
Copyright (c) 2013 CA. All rights reserved.
Connecting to manager "wwwww01b" as user "<default user>" ...OK.
List of attributes of job “prod 3 1.0:inst “ from container "myContainer"
Job name...............................: prod 3 1.0:inst
Software...............................: prod 3 1.0
Procedure..............................: instCrash
Deliver at.............................: 20035-04-12 10:49
Activate at............................: 2005-04-12 10:49
Status message.........................: OK
Overall state..........................: ERROR
.........................................0 - job targets waiting
.........................................0 - job targets active
.........................................1 - job targets ok
.........................................1 - job targets failed
Job task...............................: install
Pre action..............................: no action
Post action.............................: no action
Prompt user............................: Yes
Characteristic flags...................:
.........................................local time/exact
.........................................calendar controlled
Delivery calendar......................:
User parameters........................:
Prompt during..........................: 1 Days, 0 Hours
Job timeout............................: 7 Days, 0 Hours
sdcmd<A000000>: OK
