This action removes subgroups from a software group. This does not mean that the subgroups will be deleted.
swLibrary action=removeGroupFromSWG [name=group_name]
{subGroup=group_name}
Specifies the name of the group from which the subgroup is removed.
If this parameter is not coded the top level folder "Software Package Library" is assumed.
Specifies the name of a subgroup to be removed from the group.
The parameter can be coded more than once to remove a list of subgroups.
The subgroups are unlinked from the group.
This process fails if the specified group is the only supergroup of the subgroup. Such a subgroup can only be deleted with the action=deleteGroup.
Removing a subgroup from a group does not mean that the subgroup is deleted.
