This action allows you to add new subgroups to a software group.
swLibrary action=addGroupToSWG [name=group_name]
{subGroup=group_name}
Specifies the name of a software group that will be expanded by the new subgroup of the parameter subGroup.
If this parameter is not coded, then the top-level folder "Software Library" is assumed.
Specifies the name of a subgroup to be added to the group.
The subgroup must already exist as a group in the software library.
The parameter can be coded more than once to add a list of subgroups.
